HD-FT water to air intercooler
I will also put the same 40mm ntc sensor per ic as i have post ic, instead of the current 20mm, i believe trhe short stick sensor doesn’t give the true reading pre ic, most likely missing 10degrees, due to its jacket thermal conduction
They make air temp sensors like this: AEM Electronics 30-2014 AEM Electronics Air Inlet Temperature Sensor Kits | Summit Racing - https://www.summitracing.com/parts/avm-302014 probably going to put that in mine and let UTcomp turn the pump on at 100 degrees or so.
I have a smaller heat exchanger as i want to keep AC and run a auto trans cooler. Ill have some temp data from my build later this year.
