Popped down to Awill4x4 today for a little Tig time.
Tks Andrew and hope you Enjoyed the ride
Now I can measure pre and post intercooler, once connected up.. Also braced the rear intercooler radiator.
Spent the evening calculating Turbo outlet temps for the Garrett GT3082R @ 70F/21C ambient and from what I can work out at 9psi the outlet temp should be around 180F/82C at 15psi the outlet temp rises to 227F/108C.
So your intercooler effectiveness = actual temp drop/total temp difference
Cruising.
(50-25)/(50-12)
= 66%
Giving it death.
(82-31)/(82-12)
= 73%
That's a very good result. Do you know what your cooling water temp levels out to?
Well just one job left to do, something that should have been thought about at the start but as we all know you always miss the simplest things
Going to drill and fit a small bleed nipple to one end of each of the end caps to remove the air from the the system this should help with the heat exchange too. Then it will be even better![]()
just out of curiosity what are cores worth these days as i couldnt find any on ebay but want to build an intercooler for my hj75 turboed 2h im trying to build at lowest possible cost as the missus hates me spending money on the ute
guess ill just have to save up then but wether its worth it or not is another matter as i fitted my egt sensor from ThermoGuard Instruments to the inlet manifold pipe as it exits the turbo today and all i got was 90 degrees at 9psi @ 2700rpm i can hold max boost for ages on the highway as the poor old 2h struggles to sit on 100kmh held flat even though its only done about 15000 km since rebuild mabe ill try the fuel delivery screw and see if i cant get a bit more out of her https://forum.ih8mud.com/diesel-tech-24-volts-systems/90288-fuel-delivery-screw.html
