I hope, when you do your testing, you give us a not i/c kw/nm as well as an i/c kw/nm output. Temps/pressures as well would be nice... Looks the goods Matt, keep it up![]()
We will only be testing with I/C on, although it would be interesting, but @ $160 Per Hr and 5-6 hours work dynoing, time is money as they say.
But we have a very good idea of of inlet temps without an intercooler. More interesting will be the pre and post air pressure readings of my design. along with post air temp.
I mean test with the i/c not operating not removed... but yes I hear what you're sayin' abt the $$$$.....![]()
Did you know how much CFM you have in this electric fan . ? how muchs amps it need ?
Amazing job dude ..
No idea it's a pretty small fan and radiator out of a Mazda 121 tiny little car, amps are no issue as the fan and the Craig David pump will run off a 100 amp solid state relay like these I use for my head lights. I have a big alternator
If the radiator is not big enough to remove the heat from the inter cooler I will just go to a larger twin fan. I guess it depend how much time I spend on boost![]()
Wow, nice set up! I doubt you would need a bigger fan though, the other glycol.air intercoolers have alot smaller rad and fan than that. You should solder those relay connections though, makes em look better
Will that rad mount be stable on a washboard road?
