Home Brew Intercooler
BTW: Dougal, I like your sig. A friend of mine is a civil engineer working on a hydro dam right now. He loves it (for the most part).
Thanks. I stole it from an engineer on another site.:grinpimp:
I'm mechanical type, have done some hydro-electric work and considering going back to it.
Well from my drawing Dave good friend and Navi came up with this and it's in one piece. Just need to sort a radiator out now with a thermo fan 12" I think, so we have the size for the piping.
:crybaby:
:cool:
My excuse is I don't have CAD on my Mac:grinpimp:
We also elected to cool the Turbo from the slightly warmer engine cooling system rather than the chilly intercooler.
Spent the evening calculating Turbo outlet temps for the Garrett GT3082R @ 70F/21C ambient and from what I can work out at 9psi the outlet temp should be around 180F/82C at 15psi the outlet temp rises to 227F/108C.
Now if the intercooler is as good as I hope we should be looking at some good results.
If I have done my math right and built an intercooler that works.
Calcs using this.
http://www.gnttype.org/techarea/turbo/turboflow.html
If I have done my math right and built a intercooler that works.
Calcs using this.
For 70% efficiency my spreadsheet brings out almost the same numbers (81 and 113 deg C).
Can't wait for the intercooler outlet temp measurements.:)
I am a mac user too (since about 94). Use them at work all day. You could run any windows app you want via parrells, and coherance. Fits right in. But you might not want to. Or you could go the "old fashion" way with bootcamp.
Also, it makes good sense to leave the turbo on engine coolant lines. I was wondering if the intercooler system could keep the water cool, as well as the turbo. Not to mention the cracking issues.
Cheers,
N.
All quite now until it's fitted, will make the water splitter up over Xmas.
New engine should arrive 21st Dec. Will also source a radiator and Thermo fan.
So all I can say is watch this space in 2008.
Until then Merry Xmas and a HAPPY NEW YEAR:beer:
Ok getting there, engine was delayed but sometime next week should see it fitted. Then onto fitting the intercooler and Turbo Manifold and all the pipe work.
But for now the mountings are sorted, just need to get Awill4x4 to weld them on. So we have something like this.
Looks great.
But that corrugated hose from the intercooler to the throttlebody, is that needed for movement of parts?
A smooth hose would give a lot less turbulence to the flow.
Looks great.
The hose is just for set up awaiting one with a custom bend in smooth silicon.
Wiring for the air temp sensor is done Monday will see me pick up the 90 degree hose tail water fittings water fittings.
Then all I need to do is mount the radiator, water pump and connect the lines.
Dyno is booked for the 19th May :steer:
Looks great.
I guess 99% isn't good enough for some folks, I will say NICE FRICKEN job!!!!!!! Awesome install!!!!!
eric:steer::steer::steer::steer::steer:
Dougal is right, as of today it looks like this.
