Evening folks:
So have everything wired up as per Holley and am using the Robb MC power surge along with it on a 74’ FJ40 with DUI distributor. I can’t seem to get this thing to start. It’ll crank and every couple times or so it’ll fire up and quickly die. My assumption is it’s not getting enough fuel. I’ve ordered a fuel pressure gauge to add to the “in” on the sniper. Open to ideas here.
Things I’ve checked in the meantime:
- Mechanical fuel pump is fuel.
-Robb MC power surge is full with fuel and primes with the key in ACC.
- Distributor is grounded, has a good 12v switches, and is installed correctly.
- pulled starter and cleaned. Works like it should I believe.
- New OEm fuel filter before mechanical pump
- New Earls EFI filter in between Robb MC output and Sniper input.
- New spark plugs gapped to .050
- New live wires.
- New live wires.
