- Joined
- Dec 8, 2006
- Threads
- 158
- Messages
- 2,974
- Location
- Greenfield, MA
- Website
- thecarpentryway.blogspot.com
- Thread starter
- #861
Made some more progress on the wiring:
-discovered that the Optima battery was far from charged and that was why the starter solenoid was not activating. The battery is on trickle charge now and should be looking decent by tomorrow morning.
-found that I hadn't connected a wire that ran to the rear of the truck, sorted that out and now all the lights, except the headlamps, operate. Still working on the front marker lights, which come on as soon as the key enters the ACC position. Somehow power from that circuit is getting to the marker lights and I haven't tracked it down yet.
Another difficulty occurred yesterday when I put power to the glow circuit: the little wire coil in the Glow plug controller, visible through the mesh screen in front of it, glowed cherry red. As I had never seen one operate, I initially thought "great, it works!" - then after 3 second's operation, the wire coil abruptly snapped in half.
I learned that the reason why I fried the glow plug controller yesterday is that I forgot to connect a little wire across the junction where the line comes in from the glow relay to the controller, so that left the controller wired in series with the glow plugs, instead of in parallel as it is supposed to be. My bad. I had planned to do it, but omitted to do so. As the controller was hooked up in series it received the full jolt of current fromt he relay, instead of the distributed load it should have received. I learned from John at E4 that the controller coil only glows a dull red, not cherry red, so now I know what to look for next time I put current to one.
It looks like I can get another one of these little controllers though, either from Oz or Japan.
My multimeter crapped out so I need to get another tomorrow am.
The remaining wiring issues to solve:
-the ACC power going into the front marker lights problem
-the brake warning light circuit not coming on issue
-sedimenter circuit light not coming on fiasco
Also, getting the starter motor to turn the engine over is a step I need to take.
I think I need to go the whole way here, and get the engine running if I can, before pulling the harness out for wrapping. I can get the alternator bench tested to see if it is operating correctly as well. Ditto for the starter motor. I switched the internals from the 12v. one I had into the 24v. one's housing. So I'm not 100% sure how well, or even if, the starter works properly. With a single battery and a 6 cylinder to crank, it needs to perform well.
This wiring diagnosis phase is stressing me out big time, but this is a good opportunity as well.
I wonder if that button puts 12V +Ve onto terminal S?
oh yeah!
