Cool, thanks, I got it off. Now I have even more questions. My symptoms are:
a) glow "controller" or "indicator" or whatever never glows...
b) hard starting after a cold night, even with a 20 second glow.
I did some poking around and I find:
a) I get 1 volt measured across the glow controller/indicator
b) I get 7-8 volts across the glow plugs
c) I get 12V across the battery
High school physics tells me that you have only 1/3 of the "heating" power at 7volts as you do at 12volts, so this may be my starting problem. I know from reading other posts that this is probably a bad ground... but which grounds are the usual suspects and what is the best way to "improve" them??
See electrical diagram below, I'm wondering how things are layed out INSIDE the relay...? I gather that both wires from the ignition switch go to the relay coil, that much is easy. Also its easy to see that the "S" terminal on the relay gets switch on to Batt + (because this feeds the glow plugs).
But what does the G terminal do?! It the return from the glow controller; does it just switch to Ground (if so, what a silly design, why switch it twice?!)? Does the glow controller actually control the relay in some way??
