Wanting to bolt up this hitch to the cruiser. Does it face mount to the frame or does it need to go inside the rails?
That's the plan. Ordered a wire wheel brush for my grinder from amazon today actually. I am pretty sure the holes line up. Just need some spare time to jump on it.Hard to tell which hitch that is but if you are lucky and all the holes line up then just bolt it up. I highly recommend you wire wheel the frame rails clean as well as the mating surface on the hitch. Then prime and paint both surfaces and I’d go one step further once the paint is dry and hit that area with some lanolin or other spray on water repellent or even a healthy coating of grease just to help prevent future corrosion.
