Hello Folks!
Just joined the Forum, I am a member on the GXOR group on FB. This will be a little winded but please hear me out
I purchased my 06' GX470 last October with 225k miles. Before that, I owned a 19 Tacoma TRD OR. I was able to sell that with 51k miles for what I got it brand new and use the extra money to buy my GX outright and some mods. The owner told me he had to change out the radiator due to a crack between the transmission section and radiator section, I looked at the radiator and everything looked ok, no milky fluid or anything. I bout it for recreational purposes and really don't drive it.
Fast forward to April this year, I took my GX to the beach for a 3-day campout, roughly 8 miles down the beach I got the A/T Oil temp light. I immediately pull off the patch and let it cool down. While cooling I pulled up some forums and it said I shouldn't be in D, but rather 2nd gear or something, I wasn't sure because my Tacoma was manual and a pig so naturally driving through deep sand, I was in 2nd gear just ton have some kind of power. I also noticed that the transmission will not always go into 5th gear, like I will be going 60-70 and it will be around 2300-2400 RPMs, I am running 33s so maybe thats throwing it off a little. When I got home, I did the drain and fill using AISIN ATF0WS fluid. I figured AISIN brand would be fine sense they make the transmissions, its WS and also a good price. I also purchased a scangauge II to read transmission temps during the process. During the fluid change, it seemed to flow fine, sometimes off the start it would spit it out, maybe air in the system, but it would drain fine with the engine running. After doing the drain and fill, running the transmission to temp (above 120F), and checking the overflow while running, only a little fluid came out, so it seems to be topped off properly. I am still getting temps around 200-210 degrees and 5th gear still doesn't engage when I think it should, all other gears seem to be strong.
SO...... I'm at a loss right now, I don't know if I have a blockage somewhere, I would this not sense the drain and fill went alright. Did the last owner buy a cheap radiator and maybe its causing this problem? I might pull the hoses off this weekend and look form any blockages.
