- Thread starter
- #181
Moving forward in the vehicle, I got some wiring sorted out for the Goal Zero power station, with some instructional help from my brother, who's an electrical engineer. I also added a large power strip to the back of the front passenger seat.
Here's the power station:
What's happening here is that a GFCI extension cord is plugged into one of the 2 AC outlets on the Yeti. This cord provides 3 outlets of it's own. Two are attached to lines that run under the second-row seats to the molle panels in the cargo area, and one is attached to a line that runs right up to the back of the front passenger seat, at the base of which the Yeti resides. Each of these lines terminates in a power strip. I have the GFCI attached to the power station in a way that allows it to double as a shelf for the USB cords. So if someone accidentally pressed down on one of the USBs, the GFCI would help prevent them from bending inside their jacks. Meanwhile, the straps running from the handles to the seat bolts keep the Yeti from falling backward and smashing the plugs against the second-row. The waterproof external power inlet that I converted to an outlet is plugged into the other AC outlet on the Yeti. As I showed in a previous posting, that external outlet connects its own GFCI at the device-end of the line. Of course, during normal use of the vehicle, I will keep the external outlet line unplugged from the Yeti for safety reasons.
I used to have the Yeti sitting in its dedicated foam bag, but now that I expect to use a lot of power on some days, I've abandoned the bag so that the Yeti can stay cool.
Here is the power strip at the back of the seat. No rocket science here. I was happy to enjoy a moment of slide-in simplicity.
