Badass build. Where in jersey are you? I’d love to see this beast in the flesh sometime.
I do not fully understand where the wire came in, I spent some time today with a buddy and it appears at every entry point the wire will get pinched. Would you be able to share a photo of the entry from antennae. Did you use anything to keep the wire in place as it ran down the hatch? Thanks!Followed the lead of @SharpeCat and others here, and installed the Weboost Reach OTR. Happily, I also have a new spot in my loft building's garage, with much better light for photos.
I mounted the antenna to my FrontRunner rack using the Rhino-Rack mount. Worked out well, but we'll have to see if the one-bolt install of the bracket to the rack's cross beam holds up over the long term (I did use threadlock). One annoying thing about the mount that I don't like is you have to secure/unsecure the hinge with a screw when changing position; I wish the process were quicker.
I mounted the central box to one of my molle panels with zip ties and mounting tape. For power, I'm using the car's native DC outlet at the back of the armrest console.
Ran the external antenna wire down the hatch and under the lower hatch door plastic piece. Then made a notch in the weather stripping, close to the middle of the vehicle, and brought the line back toward the corner and into the vehicle.
I haven't gone anywhere with low signal yet, but the unit turns yellow into green on my signal meter app when inside the garage, so I already see a difference.
Very happy with the unit. Thanks, everyone, for sharing your experience with
What is your total height with lift and rack? Trying to determine if I can get into my garage with a similar set up? Nice looking ride!
I'm just under 8 feet with my cases on the roof (not including the antenna). Subtracting the cases would get me into the low 7s.
Heck I'd be happy just seeing some pics of it sitting doing whatever it is you're doing right now!Sorry--haven't been on for a while. Been busy!
No updates, really. I'd say the build is mature at this point. Mainly been working on some photographic rigging and such for creative projects. And got a little more welding to do in the front to better support the hitch mount added to the bumper. I'll share that once it's done! Mainly been using the truck for work. But I do hope to get out for a weekend trip sometime soon, in which case I'll try to get some proper pics.
Merry Christmas! Looks like someone is about to pump out some pull-ups.Here's the beast at the top of a hill. That snow got pretty deep, and the stuff on the bottom was deeply packed. The KO2s couldn't manage the job in the deep stuff, really; so we had to basically plow tracks by backing up and heaving forward a few times.
Driving around the flat trails in the snow was pretty easy. No issues with KO2s on level ground in the snow. Those Michigan forest branches, though, required some manual maneuvering.
For my next trip to northern country, I'm definitely going to get winter tires on. I had Blizzaks but sold them after getting my lift and larger tires. Thinking about the 33" General Arctics with removable studs.
After following this build I fear she's strung up...Merry Christmas! Looks like someone is about to pump out some pull-ups.
