Help with Vac Lines
Martinez, CA.
Haven’t gotten a hold of an emission book, yet. But can someone help me with this. Looks like one line was looped back….while another is missing.
Thanks.
The VCV (23275 on the schematic I posted above) has four ports. I only see 3 tubes connected. The one on the bottom (as oriented in the schematic) is connected to manifold vacuum. If that piece of tubing is not connect to the VCV or plugged you may have a vacuum leak.
Ok I’ll take a look tomorrow. Just reconnected that one I inquired about and what
a night and day difference. Able to use all 4
gears without any bogging.
The plan is to inspect and replace any bad vacuum lines, reconnect as well.
You’ve been a big help. Thanks!
Pulled the cat. Had a new one installed. NOW I can drive past 45 mph. Will do a complete tune-up and valve adjustment next.
