Hey all! I just acquired a 99 LC for practically nothing. The engine purrs like a kitten and has lots of power but there is a problem in the Transfer Case area and hoping someone can help point me in the right direction before I put it up on jacks and start taking it out.
Description - vehicle only engages when the center differential light is lit on the dashboard. Being new I'm not sure if that means it is locked or unlocked. With the the indicator light on the transmission engages easily and smoothly whether in High or Low gear. With the indicator light off when you shift into Drive or Reverse nothing happens.
Question: What is the most likely cause of this? Is it a failing/destroyed transfer case? Failing transfer case motor? Sensor or switch failure? All or none of the above?
I haven't yet pulled the drain plug on the transfer case to see the condition of the lubricant, but vehicle drove home 140 miles without a problem.
All help is appreciated!
