Help with 3-link on '99 4-Runner
Hey, what's up Justin! I got a little further tonight on the Runner. Body mounts cut off and spare tire crossmember removed.
I repositioned the rear section for a little fine tuning and to find where the body mounts need to be relocated.
Body mounts tacked in place for a second look.
Body mounts were good so they got burned in.
Then is was time to start stitching the body back together. I didn't realize just how much the rear tapers off until after it was cut. It's over 1/2" narrower then it was 8" ago. Oh well...nothing a little squeezing won't fix. I wish I had a friend who could do this part for me. It's not pretty but I plan on covering up the inperfections with bed liner. No bondo and clear coat here!
I ran out of time but couldn't resist a little mock-up.:D
looking goooood!
are ya going to bed line the entire truck or just the back portion?
On that last pic with the tail lights in. Did it already have that gap at the top? I'm assuming that's where the tailgate used to close and fill in. Did you have something there before you chopped it? Are you going to put something there?
Thanks guys. I'm undecided on how to go about covering the scar with bed liner. For sure only the back but I'd love some suggestions on where and how to tape it off so it looks good when it's done. I was playing with the idea of some kind of swoosh or angle, maybe leaving the fuel door green (no it's not fuctional) and ideas please?:hhmm:
Sam, the brake lights get boxed in a bit by the rear bumper - see post 317 but yes they kind of hang out there. You are correct, the void is from the missing rear hatch.
My seats arrived on Friday. I decided to take a break from sheet metal work to play with them instead.
First I took out the driver's seat and tore it apart.
Here's what I was left with.
I spent a few hours last night pondering how to make this work. I wanted to keep the power slide adjustment to accomodate different leg lenghts in case someone else wanted to drive. Finally it came to me. I cut free everything I didn't need. Here are the slider rails free of the tilt and seat back brackets.
I cleaned and re-wired the power slide assembly and bolted them back together.
Then I made up some 2x2 angle brackets to which I could bolt up the seat. Here it is set in place.
I set the seat in to see how it would all fit.
All was good until I climbed in for a feel. The seat is about 3" too high! All that work for nothing!:censor::mad::bang:
I'm going to have to lose the slide adjustment all together and build a plate low on the floor to bolt the seat to. I was so excited for this to work but it's back to the drawing board.
If you make the legs on these mounts lower (take as much height out of the leg as possible) you can still use the power slides. But the right slide might not have enough room to do that without changing the mounts in the floor.
A little more work done this last weekend. Scott, you're right about not being able to use the slide without major modifications to the floor mount. The problem is mostly on the inside along the tranny tunnel. Here the seat really needed to be set right on the floor to fit correctly.
I had no desire to completely redo the floor in the truck (including modify the tranny tunnel to accomodate the extra width) so I decided the seats would have to be fixed instead. Using the footings from the factory seat I worked up some brackets.
Checked final fit on the floor.
Here they are bolted to the seat bottum.
Here they are bolted in.
Repeat on the other side.... and the seats are in!
I still have to add a bar between the roll cage "b" pillars for the shoulder restraints but for now its back to sheet metal work.:crybaby:
I finally got back to work on the Runner. The bob is close to being done... body is all welded back together. A little bondo (I told myself I wouldn't) and some sanding and it was ready for Linex. I tore off all of the factory plastic and prepped it as best I could. Tonight with the help of J&K Customs here in Missoula the Linex was applied. I've got to give Jeremy and his crew due credit, they did an awesome job! The diamond plate body covers/bed caps got re-worked and re-painted. I plan to mount them up tomorrow and take some updated pics.
Here's some pictures I took today. Bed bob project is 99% done! I cleared everything out of the back of the truck and prepped it for rattle can bed liner.
I shortened and re-painted the bed covers, also with rattle can bed liner and installed them back on the truck.
Here's a better shot of the finished product. We left the toyota badge on the fuel door to get the raised effect in the linex. I still need to paint over the rivets.
And finally everything re-installed in the bed. Also replaced the fuel cell and went to a different style filler cap. Now it's on to rebuilding the rear bumper!
