little update
Advance Adapters supposedly exclusively sells the marks 3.1 tcase gears here in the USA.
LC 80 100 Extra Low
although advance is totally clueless about the gears they eventually figured it out after i personally spoke with marks about Advances cluelessness. Marks emailed advance with the info and advance finally sold me the gears today. I told the Marks international rep they need to let Christo sell the 80 series stuff if they ever want to sell it stateside. Marks told me they need to let Advance have all their product line. Something about how andvance sells the yota stuff to americans and Marks sells all the advance stuff to the aussies. Thats fine but AA knows nothing about the 80. Christo should be selling the 80 stuff.
anyway i just got off the phone with AA and baught the 3.1 gear set for $931 shipped to my door. I paid $105 for shipping. before tax the cost was $777. if you are willing to wait for the AAshipments you wont have to pay the shipping fee but i dont want to wait.
also baught a used tcase from RI and it will be here next week. will keep updated
this will be my new low range: 2.98x3.115x5.86=54.4
....until i can go lower. pending
Dusty,
While you have that extra tcase, could you take a a couple of measurents and specific pictures to confim my beliefs?
1) I believe that the tcase-transmission bolt pattern on an 80 series A44*F is the same as 60 series A440F.
2) I believe that the 62 A440F output is the same bolt pattern as the 4sp 60 series. (This should be confirmed already since people have converted to the manual tranny before without any adapter plates.)
3) The spline count and diameter of the 80 series A440F transmission is the same as the 60 series 4sp output.
4) The 3 statement above being true, one should be able to install Marlin's toybox with minor modifications. The best part is the 80 output is just a stub, and is already cut off similar to what has to be done to the 5sp H55 Toybox. I do not think the Toybox need the tcase to capture its output shaft.
My understanding of the toybox is that the tranny output does not go thru the toybox, and the 80 tcase just needs a stub to feed the power and not need the thru shaft to support the gear set like a 60 series tcase.
I guess we need a pic of the back of the transmission, the front of tghe tcase, with a couple of dimensions between bolts and across the pattern. We also need the amount of projection of the output shaft from the trasmission. This should tell us how much of the toybox input will reach the output shaft and how much need to be cut off the output shaft of the Toybox.
If the bolt patterns are the same then the adapter plates from the 60 series should work. Only issue being spline engagement.
Edit: Oh crap, I just realized you have the newer transmission right??? The A3**?
Better yet, when ya goanna drive it to work, post that on the site.
Kevin (TheBusMan)
Dusty,
Forget the measurements. I figured it out.
Thanks,
