Does anyone have the part numbers or advice on how I should continue:/ ps I’m a teenager that’s why I got myself into this situation...
Thank you for the part number, can you explain how to chase the threads?90119-10652
You are going to have to chase the threads on the other side as well or you will toast the new ones too.
Thank you, do you know what size the bolt thread is?You'll need to get a tap to run through the bolt holes and clean them up. Basically it's recutting the threads.
Something like this.
SAE & Metric Tap and Die Set, 60 Pc.
one more question since your quite the library of knowledge, which way does the shock mounting plate go? Is it the hole side towards the car or away?90119-10652
Do you know what size tap I should use to fix the threads on the inside? And thank youSlotted side in towards center of vehicle.
Hole side is out towards the exterior of the vehicle
You can see it here:
Big thank you!
Thank you once more!Should be M10 x1.25
I don't have an 80 here so I cannot confirm.
Im 99% sure that you're mistaken.
Hole towards the center, slot towards the exterior.
The mounting plates are actually marked "L" and "R" on top.
Yes, PN does indicate LH/RH.
No, i mean each plate is marked "L" and "R" on top - to indicate the orientation in which it must be mounted.
Negative. L/R indications stamped/marked on part will always indicate orientation on LH/RH side of vehicle.
Trust me, each plate has "L" AND "R" stamped on it. On the passenger side plate the R would be stamped near the slot, and on the d.s. plate R is stamped near the hole.
