- Thread starter
- #41
Awesome! can anyone second this?!?!Precisely why I went and dbl. checked and took a picture![]()
Just to make sure the slotted inside and the hole towards outside on both sides?
I don't think that possible in less you have a bent shock.look what I've started, sorry!!! I'm still looking for a definitive answer. One of mine was installed one way and the other in the opposite way...
Dude I posted a picture, like I said they only work one way . Several other poster have already confirmed this !!!!!!!!!!Awesome! can anyone second this?!?!
The previous owner had some wonky things done service/parts wise down to the car. I know this because on one side mud is caked around the mounting plate in one direction and then the other side is the sameI don't think that possible in less you have a bent shock.
I'm going to go with the slot facing out. I just went outside and took a look at how they fit and that looks most likely.They do not sit perfectly flush, I have wrench then down right?Never underestimate stupid!I don't think that possible in less you have a bent shock.
haha, thank you for all the support!There we
Glad you got it straightened out.
So what's next on the short list?
forum.ih8mud.com
Yes and this.Dude I posted a picture, like I said they only work one way . Several other poster have already confirmed this !!!!!!!!!!
Next time you use a tap, you should ALWAYS use a penetrating oil (or any kind of oil for that matter) when doing threads. It is cutting and cleaning and the oil is used to cool and to clean while you cut.View attachment 2266905
Curbside pickup at Ace Hardware saves the day along with the guidance from MUD
Thank you for the advise, I used wd40 when cutting and I backed off quite often. What kind of anti seize do you recommend?Next time you use a tap, you should ALWAYS use a penetrating oil (or any kind of oil for that matter) when doing threads. It is cutting and cleaning and the oil is used to cool and to clean while you cut.
Also, even though you are in TX, it would be advisable to use anti-seize on threads like those, since you KNOW you will have to remove them again in a few years. It makes things much easier to deal with when you own a vehicle long-term.
I keep on hand the Permatex brand COPPER anti-seize. O'Reilly's carries it. Or Amazon.Thank you for the advise, I used wd40 when cutting and I backed off quite often. What kind of anti seize do you recommend?
Will add these two to my arsenal! Thank youI keep on hand the Permatex brand COPPER anti-seize. O'Reilly's carries it. Or Amazon.
I don't use the aluminum version because if I use it on a bolt that's going into aluminum, there is still a possibility it will seize due to the aluminum flake. Plus, the copper is higher heat and can be used on exhaust as well.
Amazon product ASIN B000HBM65O
Also, WD40 is not a penetrating oil (I used to think it was great also, but I've learned) PB Blaster is definitely a penetrating oil and works way better. O'Reilly carries that too.
My apologies, thank you for confirming. I've had check 100 times and do whatever you're doing once nailed into my head by my parentsDude I posted a picture, like I said they only work one way . Several other poster have already confirmed this !!!!!!!!!!
No worries glad you got it worked outMy apologies, thank you for confirming. I've had check 100 times and do whatever you're doing once nailed into my head by my parents![]()
The herpes of the mechanics world, one infinitesimal stray drop on a rag, and everybody in the shop gets some.
hahaThe herpes of the mechanics world, one infinitesimal stray drop on a rag, and everybody in the shop gets some.
But I put that sh!t on everything. Grew up in Rochester NY, where they mine the road salt an hour south.
Two critical tools for working on cars and trucks in NY, a Blue tip wrench View attachment 2267962 and a bottle of nickle or copper anti-seez.
