- Joined
- Jan 12, 2008
- Threads
- 293
- Messages
- 3,506
- Location
- West MI near GVSU
- Website
- www.mcdesignsoffroad.com
Has anyone tried these? I don’t care for the look of most led lamps I’ve seen on 40s.
x2 on the OEM kit. Light output is the same as the Hella. It will come with everything you need . Lights + harness + relays for a lot cheaper.... And what makes that deal even better is that they are by Koito. The only thing is that these OEM lights are flat-faced compared to the round-eye style that originally came with the land cruiser (if that matters to you). Easy plug and play. You won't have to modify your original harness to get these to work.Check out the OEM kit still available from Toyota ( 81110-60P70 ) for approx. 50 bucks. Search the part # on here for lots of info.
I connected the relay as suggested. The driver side is very dim and hi-beam doesn’t work. It's a new bulb, same as other side. It's the side furthest from the battery and ground. The passenger side is bright and hi-beam works fine. I’ve tried swapping the bulbs side for side, but the problem remains. Can anyone help with this?
Are these sold one light per part number?
Fantastic.
Toyota part houses are probably scratching their heads right now over all the headlights being ordered.
