Were you ever able to go ahead with the swap and figure out what wires needed to be swapped to gain full advantage of the lights?
If you're going to spend money on high end headlights, I highly recommend the JW Speaker LED assemblies. Not cheap at all, but worth every penny. Polycarbonate lenses, so very resistant to rocks and debris, and easy to wire in once the Mud 60 Series Collective nailed down the best method (does not require a complete harness).I cracked the hella hella headlight in just normal use on my 60. I wasn’t happy with that.
The Koito headlights are far superior. I will end up with a set of koito low beams on this 62 as well.
I made up 3x piggy tail leads and kept trying combinations until they worked (none of the suggested solutions worked for me..)Were you ever able to go ahead with the swap and figure out what wires needed to be swapped to gain full advantage of the lights?
Can anyone forward me links to the upgrade wiring harness? I see ARB mentioned; I just got to the Philippine Feb 18, 2022, and lowhi beams acting crazy. Can anyone tell me where to look for the relay? Please forward links if you have time. TyIf you're going to spend money on high end headlights, I highly recommend the JW Speaker LED assemblies. Not cheap at all, but worth every penny. Polycarbonate lenses, so very resistant to rocks and debris, and easy to wire in once the Mud 60 Series Collective nailed down the best method (does not require a complete harness).
I finally invested in a set when one of my Hella lenses got shattered, and it's one of the best mods I've done to my 62. Honestly I'd say second only to the H55F.
My 1988 HJ61 24v import from Japan, converted to LHD. They were seemingly working ok couple years ago. Drivers Lo not staying lit w/o a jumper ground on it. And most not very bright. I ll upgrade.Can anyone forward me links to the upgrade wiring harness? I see ARB mentioned; I just got to the Philippine Feb 18, 2022, and lowhi beams acting crazy. Can anyone tell me where to look for the relay? Please forward links if you have time. Ty
