1988 FJ62 Air Injection Hoses
Dallas (“M” Streets), Texas
For those of us who still retain and maintain the stock air injection system, I’m looking for the following OEM Part Numbers that I’ve Labeled A & B on the attached photo.
Also, if you replaced in the past, any after market sources & part #’s that match the same shape or can be cut to length to match the same bends and inside diameter hose size?
Just in case anyone is interested, just received this from my local Toyota of Dallas wholesale parts Manager:
“A” hose = 17342-61040
“B” hose = 17343-61030
As you’re probably already aware, both hoses NLA.
Heyo- did you ever come up with replacements for these hoses? I'm also on the hunt. Thanks.
Im on it…will be good additions to my growing 62 specific parts catalog
If CruiserMatt is “on it” I’m sure you’ll soon be seeing the best of any after market air injection hose on the market. I was able to source excellent castellated EPDM hose from a few British hose suppliers that was sturdy, durable, rugged and pliable. I have their names on file (hard copy only) so I won’t be able to access them at the moment.
I would stay away from silicone. Although extremely heat resistant & flexible, it just doesn’t blend well with the original plumbing medium of OEM hose.
Attached is how I replaced one of the air hoses.
This is encouraging info- Thank you. If you have time to share your hose source in the UK I'd be grateful. Did you order all one size for the ASV valve hoses? If so, what diameter hose did you procure? Many thanks for helping with these illusive parts.
Just completed my first DIY repair on my FJ62. New air injection hoses ☑️. Picked up a new valve check from Cruiser Parts, OEM hose clamps and wicked strong (but flexible) hoses from Samco Sport. The original damaged valve check did not want to leave its position...
Now to work my way through all the other cracked hoses. :cool:
