Heater T's the $1 version
Without coolant the metals in the engine will eat each other so there is no drama. Coolant is king. Edited above to provide extra info.
I wanted to get to the real Tee(tea) debate but my message got deleted. It must of been some cross Atlantic discrimination.
More discrimination by the power hungry
I went the 4 season galvanized version for the LX. Better and safer than copper?
The look good, problem solved... I'm waiting for mine to arrive sometime in the New Year...
They look like zinc electroplated pieces of steel. When I think galvanized I think of hot dipped steel....
At any rate it ended up being a $12 per T fix instead of a $1 fix... OK, I can live with that...
What of your old LX & the friend whose engine is going to corrode away???
from the top is a noble metal like Cu from the side that is the metal that Cu will destroy . If you even seen cooper roofs on the building it is shiny at first and then over a short time it will build this green oxidation this green (slime) will kill Aluminium and other metals. well if you like cooper T then so be it.
And once again...anti corrosion additives....
Copper turns green from oxidation when it is NOT treated with corrosion inhibitors. Steel also corrodes when not treated...engine coolant is chocked full of corrosion inhibitors.
The new owner is president of our local Mensa club and a retired rocket scientist so who am I to say anything, buyer beware.
So does that mean galvanized is approved in this discussion?
Galvanized usually means dipping steel into a hot tank of molten zinc & other metals to form a coating. According to the chart Zinc Does not cause galvanic corrosion in Aluminum.
Thinking these T's are electroplated with Zinc specifically to prevent corrosion in the aluminum components in contact with the coolant....
We will see how the trucks fare in the long haul.
Here's to making over 400k between engine overhauls.
What base material are those metal Ts?
Maybe the recipie for avoiding corrosion damage is more frequent coolant changes regardless of LL or SLL properties. (30-50k 3-5yrs including Toyota Ts) 100k as the benchmark for the first coolant change is too high. That has to be the outer limit of useful life of coolant, but I suspect it lost its beneficial corrosion protection properties earlier maybe at 60-75k. As coolant ages chemical composition changes along with its corrosion inhibiting properties, which is when weaker components start to sacrafice- like you see above.
That is what I said, change the coolant every 2yrs, just a drain and fill, and you can use whatever coolant you want, whatever heater "T"s you want, whatever you want, just drain and fill with pre-mixed every 2yrs and live your life.
When switching coolant types make sure you flush the cooling system first, then use whatever cheap coolant you want. No need to spend $20/gal on coolant, $8/gal coolant will be perfectly fine.
I use Prestone Universal 50/50 because it is cheap and it works perfect in anything and I can get it anywhere, the gas station, the grocery store...so if I ever need to top off for any reason and I'm on a trip there is no need to search, wait for the dealer to open...pull into anywhere and buy a gallon. Done.
K-eep
I-t
S-imple
S-tupid
Always remember to KISS.
