Heat riser Block off plate
Its more a case of a stock gasket vs the remflex gasket. If you are using the stock thinner gaskets then 2 gaskets and the plate is probably right. The reflex i thicker. I have a photo I can post from my phone later.
Ah yeah, Remflex gaskets are thicker. I must have missed that somewhere in the thread. I think a quick eyeball check on how the half-holes are lining up is all that's needed. Not quite there yet? Add another gasket. Already there? Leave it alone.
So heat diffuser (I guess I will call it) and the block off plate are the same thickness. Yes the Reflex I'm sure are thicker. but double? I have old stock smashed gaskets not sure if that will help me.
In my photo the remflex gasket before it’s torqued is easily 4x the thickness of the block off plate.
The best solution to all this…3fe exhaust manifolds.
What is the best way to trim the rotating door inside the manifold? I feel anyway you do it metal will be in there, I would like to avoid that.
I guess thinking about it. the "door: would just stop on the block off plate. Any risks there?
You can 'lock' the flap in the open position with the block off plate, but if you want the least exhaust restriction, best to remove the flap, but then you will have to weld up the hole left by the shaft the flap attaches to, as that falls out when the flap is removed.
Some have tapped for pipe plugs
image-jpg.1029789
ricks-fj60-11-19-09-017-jpg.374562
image-jpg.1029789
Somebody on here had the holes for the shaft threaded and stuck some tapered plugs in there. One of my longer term projects is to have a manifold set machined to perfection, and part of that will be tapping those holes and installing plugs. I think if you want to get rid of the heat riser functionality the best solution is to completely get rid of the whole thing - which of course leads to other problems that need solving, like two giant holes in the side of the exhaust manifold.
image-jpg.1029789
How does one "lock" it open? Is the blade just riveted on the shaft? looks like it, but not for sure.
Rotate it to the open position and hold it there while you install the block off plate and bolt the two halves together. The plate restricts the flap's movement so it can never go "closed" again.
image-jpg.1029789
This is absolutely @Seth S and @Spike Strip area of intense experience from a life long oppressive regime out in the CA. Emissions package 📦 destination market region
Both have helped me tackle and then update the related OEM japan spec. Special Service parts now a staple main stay from
The NON-USA far-away …
As @Spike Strip puts it often , he is using modern materials with a purist based mindset approach philosophy….
Never! I'm cheap!
What ^^ he said. The flap position so exhaust is directed DOWN the down pipe.
Its seems that what I rotate it "open" with spring at max tension. It almost blocks the path more or the same as it sits at rest. I could be off.
guess what NICK ,
in T-TEN college , we had a dyno , this was before SOR invented the stainless block off plate
in ENGINES building class senior year i hand rebuit my 12/78 2F engine out of my FJ40 below
- my professor Bob EYELER suggested i completely REMOVE the shaft and flapper ,
- i was going to MIG WELD it OPEN via the SHAFT to the TITANIOUM Collar Bushings pressed into each side of butterfly shaft
- Professor Eyler told me i would BOTH run a cooler exhaust manifold and gain a notable HP increase , by removing the OPEN positioon RESTRICTION of the round shaft and the butter fly shaft all together
EXAUST AIR gets out faster = intakes faster RIGHT ! :D
well if you do not know the answer IS YES ...
- cooler manifold = cooler engine bay all around too
- take TWO M10 x 16mm HEX HEAD OEM bolts , NO SEMS WASHERS , NO FLANGE head either to be clear here
- DO NOT pre heat manifold before mig welding , your focus point is iside corner of titainum berring and carbon steel bolt
- MIG WELD ALL in ONE goot pass all around
DONE :idea:
- presto INSTANT PONIES YOU CAN INDEED FEEL , i S#HIT YOU NOT this is very real
your entire engine bay vintage parts , wires pipes etc , is now being better preserved / LESS HEAT period !
THIS IS THE WAY ..........
When I fixed mine big Exhaust leaking coming from shaft bushings of flap. So I completely removed flap and shaft. I followed the lead of post #16 in this thread.
Mine not as elegant but has worked great So far. No more Exhaust leak👍
How exactly do you remove that shaft? I'm an idiot so more detail the better.
If I remember, once I removed the flapper off, the shaft on mine pretty much fell out. Mine was leaking pretty bad from both bushings on either end of shaft. I do remember I had to cut the flapper off shaft for shaft to come out and the spring controller on the one end of the shaft (don’t know technical name) had to be removed too. I don’t remember it being difficult. Sorry if none of this helps, my Technical Jargon is seriously lacking.
And to remove the Flapper, cut the welds?
