Looks promising enjoy the build
Ahhhh I appreciate itYou need to run that big red wire from the battery to the big lug on the starter.
As I was filling the tcase I realized it was leaking BAD. Correct me on this if I'm wrong.
I just realized I forgot to to put the spedometer cable inNo, you're right. That's leaking bad...are those bolts even snugged down? As for your engine revving high, could be one or more reasons for that, certainly a distribubor being way out of time (probably too far advanced) would account for that.
Pighead's solo dist. seating maneuver: get a big end wrench that will reach between the hot lead and the solenoid on the starter motor (or one of those fancy remote starter things), put that in your left hand. Lean over the fender, maybe standing on the tire, put your right hand on the dist. cap, putting your weight on the cap. Tranny in neutral obviously, jump the starter motor to rotate the engine. You'll feel the dist. fall that last 1/4" and seat with an audible thump.
Thanks!That's the vacuum source for the brake booster...
