Headlights not working + 4Plus bumper and winch!
fort worth, Texas
Hey guys! Been working on the fj for a bit now! It's coming along. Noticed today that my headlights weren't working. however, my side markers and lights are. Any ideas? Fuses? Relays?
Check the lights are grounded and also see if you have power at the connection to the light when switch is pulled.
Headlight fuse probably takes less time to check than typing ;)
I believe the headlights and marker lights are on different fuses.
And unless modified, there are no relays for any of the lights.
(Also maybe check the bulbs aren't burned out?)
They are on separate fuses. In mine, the light switch's headlight circuit and it's plugin got hot and had to be replaced / rebuilt. I changed it all to relays and only a small amount of power goes thru the switch now.
