Are you sure you have the fuel heater? It would seem unlikely.
Could have been added also, fairly easy....
I’m curious as to when the heater turns on (on the fuel primer). I had to replace the stock winter one (with heater) last year when my diesel fuel (20 percent bio diesel) froze / gelled at -10F. I didn’t have it hooked up at the time, not that I think it would have mattered with the truck being off.
Ordered a new one and installed it recently since it was pretty obvious it wouldn’t hold pressure properly. Found a replacement and moved the heater over to the new one, but it hasn’t been cold enough for it to work yet. At least my seat heaters work great, even if the fuel heater doesn’t do much unless the truck is on.
The switch is actually a vacuum switch inside the heater itself. It kicks in at a certain "resistance" of flow of fuel. So the two leads to the heater always have power to them, when IGN is on.
I was suspect of mine as well, so I bought a hand vacuum tester and checked it accordingly to the tests in the FSM, and it passed fine. Tool was cheaper than a replacement heater so I was satisfied with that
Do you get cold temps like that on a regular basis? We often have -15 C for weeks. Sometimes dipping to -20 to -25 for a week or two.
Honestly the best mod I have ever done to my cruiser was a Webasto TSL recirculating diesel block heater. The things freaking amazing.
The fuel temp sensor is located inside the fuel tank , and it is this fuel temp sensor that triggers the heater located on the fuel primer .
