Hard Door Window Glass Replacement and Vent Window Question (2 Viewers)
What is the proper order of the hardware that mounts on the bottom pivot? I have the spring, washers, plastic washer, and metal piece but I'm not sure what order they go in for re-assembly. Thanks.
plastic washer is above larger washer...hope this helps. Now if I can just find where those hole cover/door plugs 67556-60010 went.
Perfect. I sure appreciate it. There is a little metal do-hickey that fits over the spindle. Where does it go and does it matter which way the pointed part faces? By the way, if you can't find your plugs, I bought a pair from SOR.
I bought the plugs from Sor also, but I can't seem to find my OEM plugs either. The metal c-shaped points up the lock nuts tension the spring against it and the underside of the door sill. The pic is oriented upright.
Reviving an old great thread. Before I make a mess, is it possible to remove the wing window and install new gasket without taking the door apart?
Looking back on this thread it actually looks like I got it out before I broke the glass and had to take the door apart.
Been so long. All I’ve done since I had the door off the truck
