I agree that was a bold statement.
I assumed he had meant that the steel cable supplied on all the Harbor Freight winches sucked. Mine certainly did. I would suspect the winch manufacturer cuts corners where possible to save money and boost profit, maybe buying the cheapest cable they can get. I doubt all the Chinese cable manufacturers produce the same quality cable since the replacement cable I bought is from China and much more supple than what I removed.
My neighbor has a 9k HF winch with 5/16" cable that has no stiffness or quality issues like my 3/8" cable had.
My greatest concern with the HF winch I have is that the drum is wider than the fairlead so I can't get the cable to spool tight at the edges. The cable likes to fall into that valley and lie over itself and get stuck. I have seen the same issue on other winch brands I looked at. Synthetic line would have the same issue.
I've briefly wondered if I could fab fillers for the drum ends to stop that problem.
Does anyone else have this issue?
Curious how long you been running your synthetic line? That is kind of a bold statement. I bought my first winch in 1982, a used OEM PTO winch with it's original steel cable (1972) which I still use today. Living in a dry desert climit No way would I trust a synthetic line had half that age here in the desert.
. Maybe that is what Warn is supplying.
