effjay80
Stupid question - what makes the distributor o-ring replacement easier when the alternator is off? Just easier get to top dead center? Thanks for all the great info.
I'm prepping to replace my leaking power steering pump and lines, the aging alternator with a remanufactured denso, and the NAPA belts with new OEM. It seems logical after studying my FSM and reading the MUD threads that these three jobs should be complementary and best done together. Based on the varying MUD opinions this should be somewhere between a walk in the park set of jobs or an absolute catastrophic death spiral mess.
Any secret hints welcomed!
I think @Malleus intent was if you are pulling the alternator and need to do the distributor o-ring, it makes the alternator easier without the dizzy in the way.Thanks guys. I ordered a new pump and the low pressure hose set from Wit's End, and the Rein high pressure hose assembly versus the insanely priced OEM set. The Wits End PS kit with the upgraded cooler wasn't available.
King Malleus, who's always in the know, mentioned above that the distributor o ring was an easy addition sans alternator which why I inquired.
Happy St. Paddys day to all and heading to myfirstsecond Guinness early today.
It's astounding how well this almost 30-year old vehicle runs. If I had hair, a libido, and weighed 25 lbs less I'd swear it was 1996 again!
I tighten up the tensioner bolt with the T30 on a long extension through the wheel well.
Belts are a bitch; then they slip on.
