question: Is there a reason you chose to twin stick the t/c instead of just removing the shift gate. Is that possible with the toybox?
There is a new thread on this subject on the Marlin forum
4.7 toybox install questions behind a h55f
It looks like the H55 output shaft gets cut down. I guess this means the tranny doesn't need to be disassembled like and H42/H41 for a new output shaft install.
This is great news to hear!
Aside: Can you disable these super low gears when you're say, driving two hours at 70mph to get to the rocks you're planning on crawling over?
Basically the stock transfer case linkage will not reach back to the transfer case with the toybox added without modifying it. The 2WD/4WD part would not be as complicated modifying the stock linkage since it moved back and forth but the low/high would be more complicated. It would have to move side to side with more range since the transfer case is back farther.
But....Say if you lengthened the linkage rod to meet the stock high and low lever on the Tcase, I'm thinking shifter side to side movement wouldn't be increased.
The high/low input requires a left/right movement so the arm on top needs to be reconfigured to a forward/back config.
Kevin, can you squeeze a pic where the high/low linkage connects to the t-case?
So how does one work this confiiguration? what are the two small levers for and what is the big one? I assume the small ones are for the transfer case and the larger one is for the Toybox? Extra levers and gear to play with? I love it![]()
You can remove the shift gate on the factory shifter to go into 2L.
his shifter?Thanks Nocal, thats way cool. would love to play with one.
Is this considered part of the original shifter linkage or is this in the case itself? Please explain.
Could you just move the shifter back and keep the linkage the same length?
