Wanted H55f input shaft for HJ61
bcsteel
Terrace, BC
  1. 60 Series
Terrace, British Columbia Canada
Looking to see what’s out there.. coarse spline input shaft required for a 12ht/h55 application.. shipping to Terrace BC Canada.
33311-60120 or 60121 will work that fits also 2F and 3F gas engines and 2H. These are later H55’s made 1985 plus.
orangefj45 Georg Cruiser Brothers Valley Hybrids most likely has one in stock. That would be my suggestion. That isn't a part that a typical hoarder has laying around on the shelf.
Just buy a new h55 from @orangefj45 if your box is wrecked. I had a 470,000km h55 rebuilt and it cost me $1500- and for $1000ish more I could have had a brand new zero km transmission.
@orangefj45 (George) the current possible donor is from a 1985 bj60. Production date 5/85 so I’m assuming this is an early model…If it’s easier I can give you a shout at your convenience.
@lynchmob pm’d
The best way forward is to get some specs from the existing input gear.
Seal surface diameter
Bearing surface diameter
Tooth count ( not splines )
Georg @ Valley Hybrids @ Cruiser Brothers
I have one in Qualicum beach. 24 tooth gear, 86.7mm dia. 10 tooth spline,10.5" tall, 27.7mm dia. bearing is 6308N check yours then PM and I'll send more pictures if needed
