- Thread starter
- #121
..And yes, I was doing it the way the 77 and 80 FSMs show it, which is right side up. Turning it over makes sense. ..
.. Never!!!...Lostmarbles, sometimes conventional wisdom is wrong/flawed and we have move on.
Thanks jb
Hi Vae, ... Here's a picture of a support I built for the case so the parts are easier to assemble. It makes hanging the transfer case off the back easier and it is not rolling around on the bench. ...Thanks jb
Grind a deep groove into it , then smack the groove to break it.
Grind a couple of slots into the race and use your gear puller.
Hi Vae,
Looks correct. There is a shoulder behind first gear for the race to seat on.
Rather than use the old race to push it on, take a sold punch, a piece of flat bar-mild steel or a pin punch. (The mild steel is softer than the pin punch usually so it less likely to chip the race, also the flat bar has more surface area on the race compared to a round pin punch) When you hit the end of the race, you should hear a solid thunk if its home and a more dead sound if it not. The punch tends to bounce when it home as well.
Thanks jb
Both pictures show the race seated against the shoulder of the gear.
Alle ist gut.
Alles ist gut.
Stimmt, aber noch nicht fertig.
ok, aber welche lücke ist richtig?
Als der Snap ring anziehen konte alles ist gut, sonst weiter gehen.
