Success!!! Jim C mentioned applying heat and I didn't see if you did or not but heat from a propane torch, map torch or in some cases just a heat gun can really help. On the flip side putting bearings in the freezer can aid reassembly.
When the shaft is driven out, the key will fall out.
But there is usually no need to remove the reverse or reverse shift fork. These parts have no wear issues.
Wash out the case, dry the case, lube the reverse gear and begin reassembly.
Yes, I read that, but I was uncomfortable with that. I'm in there, it looks easy to clean up, shouldn't I get the rust off the shaft and just go ahead and touch everything?
I'm bad about listening to good advice sometimes (hence the existence of this thread, several folks said "Why the hell are you rebuilding an H42?").
(Thanks for suffering through this thread by the way).
Listen to Jim. I have also never messed with removing reverse on any I have worked on. Nice work removing the output shaft bearing.![]()
When measuring the thrust clearances between first second and third gears, how should the shaft and gears be sitting?
If I hold the shaft vertically, the gap is too tight based on the FSM. If I lay it horizontally, the gaps appear to be too large, even holding the gears tight on the shaft.
Rookie. Help.
I performed the tests horizontally, and failed them all. I was *just* out of spec on all of them. I figured the tranny shifted fine when I took it apart; so I put it back together and it still shifts fine years later, despite failing those tests. YMMV, but that is my experience.
all selective fits at the bottom edge of acceptable.
He's referring to the snap rings and other selectable sized parts to adjust play.
Ha, ha! Told ya so!;p Shouldn't matter much, since 99% of the time reverse is just sitting there, not spinning.
