H150F 5 speed transmission question
WarDamnEagle
Auburn
Apologies for my laziness but here is a cut and paste from my build thread to introduce the topic:
I might need to start a separate thread but I will start here. My FZJ75 has an H150F transmission (5 speed). It has performed flawlessly since I bought the pickup except it doesn't always want to downshift from 3rd to 2nd. I changed the trans fluid to Redline Synthetic MT90 and that didn't make the issue any better so I just assumed I would need to have the synchros addressed at some point in the future.
Fast forward to today and since getting the pickup at the port it doesn't want to shift into reverse. Most of the time you need a bit of a rolling start (preferably backwards) to get it to go but when you hit that sweet spot it drops right in. It doesn't grind or make any noise; it just won't go into reverse. It's almost like you are trying to put the shift lever into an area that doesn't have a gear. I checked the trans and transfer case oil levels yesterday and they were a little low (have a tiny seal leak that I need to address) so I topped the levels off. That has not helped the issue. Again, there was zero issue when I dropped the truck off for shipment.
I am a total transmission neophyte so I thought I would see if anyone has any ideas short of pulling the transmission and shipping it off to someone. Thanks.
So, I guess my question is, who should I contact to rebuild this transmission, assuming a rebuild is necessary? Happy to hear an easier solution if there is one out there but I'm guessing every solution will entail at minimum dropping and opening up the transmission. My son just drove the pickup around 4 hours each way to our condo and there is zero change in the behavior so I doubt this problem is going to magically go away with continued use.
I have a h150f sitting in my 79 pickup, truck is not running at the moment but your welcome to come shift through the gears to get a feel for how it should feel, the transmission has 51k miles on it
Appreciate the offer. I'm pretty sure I know how it's suppose to feel. It went into Reverse smooth as butter until it didn't. :D
Have you removed the shifter to check the shifter and seat? Does the shifter feel loose in its top cover socket?
How many miles are on this unit?
Georg @ Valley Hybrids @ Cruiser Brothers
Shop 209-475-8808
Sales@valleyhybrids.com
Shop 209-475-8808
Appreciate the suggestion Georg. Someone else just asked me the same question. 270k km so about 168k miles. Let me go check looseness around the bottom of the shifter.
Georg, @orangefj45 the shifter doesn't wiggle up and down or seem to have any play horizontally at the bottom. I can still pull the shifter and take a look at the bushing but haven't yet.
So I have it parked on a slight uphill incline so that it will roll back on it's own. If you let it roll back while trying to put it into reverse it will slip right in after it rolls for a foot or so. If you then take it out of reverse and roll for even an inch it will not go back in. Let it continue to roll for around a foot and again it goes right in. The result is the same with or without the engine running. All forward gears operate perfectly except for the downshift issue that I described when downshifting from 3rd to 2nd (it has had that problem since I bought it).
I have also tried pumping the clutch with engine running and off. Doesn't appear to help at all when it won't go in. No sign of a clutch issue in any of the forward gears either.
I guess maybe as a next step I should verify the shifter bushing is OK and maybe drain the fluid to see if there's anything in there?
The only other possibly pertinent information is that this truck has a backup alarm. I think that's Saudi spec but not sure if it's factory or dealer/port installed. It is still working as it always has but thought I would throw that information into the conversation.
Hello,
H15xF transmissions have a feedback mechanism that makes a click when you shift. In this way the transmission does not slip gears as it ages, which is the case with the H55F.
Early (1992 to 1995) models had a defect with this mechanism for the reverse gear. As per the user's manual, it was necessary to stop, press the clutch twice and then attempt to shift. This problem was corrected in the mid to late 1990s.
Removing the shifter to check is the first thing to do. Then it is trying to engage pressing the clutch pedal twice.
If all this fails, the feedback mechanism needs repair.
Juan
We sometimes have an issue getting into reverse. But have found when sitting if you shift into 2nd, then the shift to reverse is possible.
Hello,
H15xF transmissions have a feedback mechanism that makes a click when you shift. In this way the transmission did not slip gears as it aged, which was the case with the H55F.
Juan
Well that is very interesting Juan. Thanks so much for that information! Two quick pumps and it will go into reverse most of the time (like maybe 4 out 5), which is much better than not at all (unless slowly rolling). I still haven't removed the shifter to check the bushing but will at some point.
So I assume this "feedback mechanism" is internal to the transmission and if a competent person were to fix my synchro problem with 3rd to 2nd that it would be easy enough to fix this mechanism? In looking at the parts diagrams, there is a reverse synchronizer on the Transmission Gear diagram and all these Gear Shift Fork and Lever parts on a separate diagram. Is it one of these?
33211FORK, REVERSE SHIFT
33211-600401
33212AFORK, GEAR SHIFT, NO.1
33212-600401
33213BBOLT(FOR SHIFT FORK SET)
90105-082113
33213GFORK, GEAR SHIFT, NO.2
33213-600601
33214GFORK, GEAR SHIFT, NO.3
33214-600401
33231HEAD, REVERSE SHIFT
33231-600201
33231EBOLT(FOR REVERSE SHIFT HEAD)
90105-070011
33242SHAFT, GEAR SHIFT FORK, NO.1
33242-600401
33243ASHAFT, GEAR SHIFT FORK, NO.2
33243-600811
33244BRING, SHAFT SNAP (FOR SHIFT FORK SHAFT)
90520-160032
33244DSHAFT, GEAR SHIFT FORK, NO.3
33244-600301
33245DRING, SHAFT SNAP (FOR 3RD & 4TH SHIFT FORK SHAFT)
90520-140032
33245GSHAFT, GEAR SHIFT FORK, NO.4
33245-600401
33261CSHAFT, SHIFT & SELECT LEVER
33261-600401
33264PIN, OR BALL, SHIFT INTER LOCK, NO.1
90250-10023L=15.452
33264BROLLER, NO.1 (FOR SHIFT INTER LOCK )
90361-10003L=13.6, OD=9.51
33264CBALL (FOR SHIFT INTER LOCK)
90360-100032
33265PIN, SHIFT INTER LOCK, NO.2
90250-10024L=56.95, OD=9.531
33275ASPRING, COMPRESSION (FOR SHIFT DETENT BALL LOW SIDE)
90501-14124L=26.34
33275BBALL, SHAFT DETENT
90360-100034
33275FPLUG (FOR SHIFT DETENT BALL)
90341-120084
33280PIN ASSY, REVERSE RESTRICT
33280-60020RH1
33280-60030LH1
33280EPIN, SLOTTED SPRING (FOR REVERSE RESTRICT PIN)
90254-040151
33283PIN, REVERSE RESTRICT, NO.1
33283-600301
33283ASPRING, COMPRESSION (FOR REVERSE RESTRICT PIN)
90508-100641
33283DPLUG (FOR REVERSE RESTRICT PIN)
96411-412001
33283GPIN, SLOTTED SPRING (FOR REVERSE RESTRICT PIN)
90254-05016
Thanks for that tip. Unfortunately that doesn't seem to help in my case.
Hello,
The feedback mechanism is described as "triple cone type synchromesh" by Toyota. Yes, it is internal, and the reverse gear part is different from the other gears.
The input shaft includes first gear, second gear and reverse.
The reverse gear uses a sliding mesh. The part number is 33381-60010.
The FSM states that it is necessary to check clearances for both gears and forks and replace them if they are out of specification.
I am not an expert on transmissions but I think that a good mechanic can do this.
Hope this helps.
Juan
Hello,
Hope this helps.
Juan
Again, very helpful. Part is around $55 but has to come from outside the US or at least outside the US dealer network. Given my issue downshifting from 3rd to 2nd, I probably should get an expert to go through the entire transmission. At least I can drive it with a bit more confidence now that I can somewhat reliably get it into reverse.
or buy a h152 from a US dealer....
$1,000 to dive into a used transmission here and at discount the h152's can be $2,500.
Is an H152 a drop in replacement for an H150f in all regards? I spent a few minutes poking around the interwebs but couldn't find a definitive answer. Maybe @OGBeno knows?
Hello,
H15xF transmissions were built to be repaired.
Some do not like the click when shifting but it is better than slipping gears in my book.
Juan
Hello,
Juan
It shifts pretty smoothly when going from 1 to 5 or downshifting from 5 to 4 to 3. No complaints about that at all.
