GX460 Transmission fluid cooler (1 Viewer)
Is there any harm in having two coolers in series? I've added the factory cooler to mine now, but I've been thinking of acquiring a heavier trailer and I think I wouldn't mind maybe adding a Hayden 679 in series.
I would get the trailer and tow a few times before thinking about adding more cooling capacity. I would also probably go with one high quality cooler vs two hayden coolers. More components will always equal more changes of failure.
For sure, all valid points
The only advantage I see is maybe having more surface area and easier mounting options, two smaller coolers instead of one larger one.
But the introduction of more points of leaking is obviously not ideal
Thanks guys. Prolly will just swap out the factory cooler if need be
  • Like
Reactions: r2m
It's pretty easy and cheap to swap out the factory cooler with a Hayden. I have a 678 which keeps things super-cool. You should not need any more cooling than that (unless you are towing up a really long grade in 3rd gear or lower where you don't get TC lockup, however you'll still be better off than stock). It's maybe a $100-150 mod all in. You can DIY a bracket where the Hayden will bolt up to the factory cooler mounting points, so it will look pretty clean and very factory-esque in nature (generally un-noticeable).
Just an FYI you are posting in the GX460 forum, where 95% of the GX460's don't have aux coolers from the factory unlike the GX470, nor the the brackets or mounting locations. Just a heads up to clear up confusion.
Understood, however the most recent poster (which I was commenting to) indicated they have already added a factory cooler. In looking at photos of the GX460 factory cooler mounting (and what others have done), it's very similar to the GX470 and it would not be difficult to make a mount for a larger Hayden with some basic metal flat stock.
You can definitely put a larger transmission cooler in the OEM location. I had a large Tru-Cool 47391 (will not mount in OEM location) on the GX470 before I swapped it over to our LX570. Then I retrofitted the 200 series transmission cooler (which is about 2 times the size of the stock GX470/460 transmission cooler) into the OEM location for the GX470. Just go to the hardware store and get a couple of brackets or aluminum plates to fabricate your mounts.
Bumping this up as I've secured parts to install a cooler.
A few questions though - after watching a few install videos, I still want to confirm which of the hose nipples are the outlet from the radiator. It looks like the short, J shaped hose, with fluid leaving the radiator from that port and returning to the trans from there. From what I understand, the correct routing is transmission > radiator > additional cooler > transmission.
Also - for those that used a Hayden 678, did you need to add fluid and how much? I need to flush my trans soon anyway, but don't want to run it low because the cooler is taking some fluid. Also, does the fluid drain out entirely with the cooler oriented sideways (ports to the right, facing the truck)? Might make doing a drain and fill a little more involved as it's going to read high when it's not running and pushing fluid through the cooler, right?
For the fluid, I'd top it off when you are done (via the FSM procedure and the fill plug on the side of your trans). It's not a particularly difficult process to do that if you have a scanguage/Bluetooth OBD2 reader to monitor trans temps, and would avoid detailed accounting of the new fluid capacity and whatever leaks out during the cooler install.
Honestly, I'd just do a full fluid exchange while you are in there anyway to avoid having to do it again in the future (with a pan drop too). You can do most of the fluid exchange via the cooler hoses that you will install for the 678. I obviously have a 470, but most of the process should be the same. Then you won't have to think about your trans for another 30-50K miles.
I did a Hayden 678 a few weeks back and didn't lose much fluid when swapping the lines so I topped off my fluid using the odb2 pin procedure. It didn't take much. I drove it for a few weeks (not many miles since I WFH.). Then I realized the thermostat hadn't opened during the fill procedure so I pinned it open and did the procedure again and it tool almost a quart.
Here is how mine is mounted. Only needed one bracket and the horns were mounted on the middle support.
With the cooler mounted so the inlet is at the top and the outlet at the bottom the fluid will drain into the trans when it's not running. But you set the level with it running and at temperature so it doesn't matter.
Make sure to pin the AT thermostat open when setting level
View attachment 3617657View attachment 3617658
Pin thermostat open with 1.5mm pin and idle until AT Pan temp is 115-126° in Fusion before removing overflow plug (one more new crush washer needed) to set ATF level.
Check. (and leave stat pinned open in my case) 👍
Should you cycle through gears while AT is getting up to temp?
Great question and you made me look it up. Finally got the FSM for my 19 last night. Appears that is a yes.
Readers Digest version:
(c) Start the engine and idle it.
(d) Slowly move the shift lever from P to S, and then change the gear from 1st to 6th. Then return the shift lever to P.
HINT:
Slowly move the shift lever to circulate the fluid through each part of the transmission.
(h) Allow the engine to idle until the fluid temperature reaches 46 to 52°C (115 to 126°F).
(i) Remove the overflow plug and gasket with the engine idling.
(j) Wait until the overflow slows to a trickle.
(k) Install a new gasket and the overflow plug.
Torque:
20 N·m {204 kgf·cm, 15 ft·lbf}
You can, however, definitely re-use the crush washers. All of mine have been re-used several times now (trans, diffs, TC) - no leaks. The only reason they should need replacement is if one is mangled somehow.
I agree and have re-used plenty of rush washers in my life.
I will mention that I found this full set washer kit for $7 if someone wants an easy way to replace them.
I know people reuse them but as a retired Navy Chief Machinist Mate can't bring myself to do it. Especially when the tech manual specifies to use a new one and the edges of the old one have been crushed already. Hell if I caught one of my men using an Oklahoma socket set (crescent wrench) I'd threaten to beat them with it, I don't need any round head bolts in MY Engine Room. Then I'd go topside and throw it overboard.
But the Chief may have always kept one in his locker, I will neither confirm nor deny. Because 3/4" wrenches on a ship = 10mm on a Toyota LOL. And an ACE hardware store was always a very long ways away.
  • Like
Reactions: r2m
