GX460 Highest Mileage (2 Viewers)
Funny.. and KBB is usually low for my area
2025-08-29 (467,800 mi)Toyota of Gallatin
Service: Multi-Point Inspection, General Concern
Description: Towed in for possible head gasket issue, inspected
2024-04-03 (463,183 mi)Toyota of Gallatin
Service: Multi-Point Inspection, Oil/Filter, Tire Rotation, Air Filter
Description: Oil & filter change, rotated tires, replaced engine air filter
2024-03-01 (461,050 mi)Toyota of Gallatin
Service: Brake Booster, Alternator, Battery, Wheel Bearing
Description: Replaced brake booster, alternator, battery, wheel bearing; heating concern noted
2023-09-29 (457,650 mi)Toyota of Gallatin
Service: Drive Shaft Replacement, Inspection
Description: Installed drive shaft, performed inspection
2023-04-11 (456,014 mi)Toyota of Gallatin
Service: Vibration Diagnosis
Description: Rear bearing & drive shaft vibration, warped rotors, recommended replacements
2023-02-28 (447,793 mi)Toyota of Gallatin
Service: Water Pump, Drive Belt, Thermostat, Inspection
Description: Replaced water pump, drive belt, thermostat; multi-point inspection
2023-02-25 (447,693 mi)Toyota of Gallatin
Service: Cooling/Temp Concern, Inspection
Description: Temp gauge moving, added coolant, dash lights on, inspected
2022-10-14 (418,893 mi)Toyota of Gallatin
Service: Brake Inspection
Description: Brake grinding, replaced caliper, pins, pads, rotors due to fluid leak
2021-10-07 (347,496 mi)Lexus of Nashville
Service: Transmission, Ignition Coil, Valve Cover
Description: Cylinder 3 misfire, oil in spark plug tube, replaced ignition coil, valve cover reseal, plugs replaced
2021-07-05 (332,841 mi)Toyota of Gallatin
Service: Inspection, Vibration/Braking
Description: Replaced power steering rack, resurfaced rotors, replaced pads, studs/lug nut
2021-05-27 (325,012 mi)Toyota of Gallatin
Service: Transmission Replacement
Description: Transmission slipping, replaced transmission & fluid
2020-02-19 (262,263 mi)Toyota of New Bern
Service: Drivability Concern
Description: Replaced rear axle seal, shoes, brakes
2020-01-23 (255,003 mi)Lexus of Nashville
Service: Burning Smell, Transfer Case Leak
Description: Replaced transfer case input seal, declined valve cover gaskets; loaner provided
2019-12-30 (253,677 mi)Lexus of Nashville
Service: Transfer Case Fluid Leak
Description: Estimate for transfer case seals, burning smell from valve cover leaks
2018-05-03 (163,163 mi)Lexus of Nashville
Service: Brake Concern
Description: Rear rotors warped, calipers deteriorating; oil/filter change; brake fluid service; replaced front caliper & hard line
2017-10-12 (147,682 mi)Lexus of Nashville
Service: Oil & Filter, Airbag Recall
Description: Oil/filter change, replaced passenger airbag inflator, brake inspection
2017-04-13 (134,813 mi)Toyota of Gallatin
Service: Presale Inspection
Description: Recommended cabin/engine air filter, wipers
2017-02-22 (121,450 mi)Lexus of Nashville
Service: Oil & Filter, Inspection
Description: Replaced engine air filter, inspection noted wipers & cabin filter soon
2016-08-25 (105,615 mi)Lexus of Nashville
Service: Oil & Filter, Brakes, Tires
Description: Rear brake replacement, new tires, alignment, front brake service
2015-11-19 (80,539 mi)Lexus of Nashville
Description: Oil & filter change, reinstalled locking lug
2015-09-15 (75,651 mi)Lexus of Nashville
Service: Brakes
Description: Machined all 4 rotors due to grinding & vibration
2015-07-16 (72,264 mi)Lexus of Nashville
Service: Brake Pulsation
Description: Possible seizing caliper, warped rotors; repair deferred
2015-06-16 (70,535 mi)Lexus of Nashville
Service: Check Engine Light
Description: Code P0010 camshaft actuator circuit; repaired damaged wire harness
2015-05-12 (68,181 mi)Lexus of Nashville
Service: Check Engine, Steering Drift
Description: Replaced secondary air injection pump/valves; alignment recommended
2015-04-09 (65,001 mi)Lexus of Nashville
Service: Oil & Filter, Air Filter
Description: Basic oil change, replaced engine air filter
2014-12-16 (57,001 mi)Lexus of Nashville
Service: Oil & Filter, Battery
Description: Oil change, battery replaced
2014-09-04 (47,871 mi)Lexus of Nashville
Service: Oil & Filter, Seat Recliner
Description: Oil change, seat recliner binding (declined repair)
2014-06-12 (42,764 mi)Hendrick Lexus Charleston
Service: 40,000 Mile Service
Description: Oil/filter, tire rotation, air & A/C filters, belt inspection, detail service
2012-12-03 (28,562 mi)Hendrick Lexus Charleston
Service: 30,000 Mile Service
Description: Replaced oil & filters, brake fluid, alignment, inspection
2012-07-04 (23,920 mi)Hendrick Lexus Charleston
Service: 20,000 Mile Service
Description: Oil/filter, tire rotation, fluid check
2011-12-14 (18,635 mi)Hendrick Lexus Charleston
Service: 15,000 Mile Service
Description: Rotation, alignment, wipers, air filters, driveshaft lube
2011-05-11 (13,580 mi)Hendrick Lexus Charleston
Service: 10,000 Mile Service
Description: Routine 10k service completed
2010-10-26 (8037 mi)Hendrick Lexus Charleston
Service: 5,000 Mile Service
Description: 5k service, buffed scratch, complimentary wash
2010-08-03 (4621 mi)Unknown
Service: Smart Key Programming
Description: Programmed smart key
2010-08-01 (4079 mi)Unknown
Service: Delivery Prep
Description: Clean for delivery
2010-05-11 (4078 mi)Unknown
Service: Certified Pre-Owned PDI
Description: CPO PDI, detail, window tint removed
2010-05-10 (4048 mi)Unknown
Service: ALB Campaign
Description: Computer updated per ALB campaign
2010-02-14 (6 mi)Unknown
Service: Pre-Delivery Clean
2010-01-31 (5 mi)Unknown
Service: Pre-Delivery Inspection
Description: PDI for USA all altitudes
  • Head gasket (suspected/inspection requested)
  • Engine air filter (multiple times)
  • Brake booster
  • Alternator
  • Battery (multiple times)
  • Left/Right wheel bearings
  • Drive shaft (replaced twice, one actuator order noted)
  • Rear bearing
  • Brake pads (front and rear, multiple replacements)
  • Brake rotors (front and rear, resurfaced and replaced multiple times)
  • Calipers, pins, shim kits (due to leaks or wear)
  • Water pump (multiple times)
  • Drive belt
  • Thermostat
  • Power steering rack
  • Ignition coil (cylinder 3)
  • Valve cover gasket kit (reseal performed)
  • Spark plugs (full set replaced)
  • Rear axle seal
  • Brake shoes
  • Transfer case input seal
  • Front brake caliper & hard line
  • Airbag inflator (passenger front, recall replacement)
  • Wipers (recommended/replaced at least once)
  • Secondary air injection pump & valve sets
  • Wiring harness repair (camshaft actuator circuit)
  • Tires (full set replacement, multiple rotations and alignments)
  • Stud and lug nut (rear wheel)
  • Cabin (A/C) filter (multiple times)
Used Lexus GX 460 460 for Sale in Gallatin, TN | Toyota of Gallatin - https://www.toyotagallatin.com/viewdetails/used/jtjbm7fx1a5003663/2010-lexus-gx-460-sport-utility?type=cash
They probably also don't have a lot of data to compare to. Can't be more than a GX or two a year with that many miles with which to build their pricing model on.
Being that the dealer didn't send it straight to auction, perhaps they picked it up at a very low trade in price (say $2-4K) and are trying for a flip. Still, can't imagine that being an easy flip to make, and most new car dealers don't keep 15-year old rig with nearly 500K sitting on their lot.
EDIT: LOL, didn't see the service history. Literally unloaded on Friday with a head gasket issue, now for sale for that kind of a price. Nearly 500K ain't bad for any motor, but it also ain't 1M miles like a 2UZ-FE will go :). With 500K and motor issues, that's a Mechanic's Special and should be sold for more like $2K.
Remember there are a few examples of 1UR-FE's that have gone nearly a 1M miles (900-980K).. there were a couple examples on GXOR FB years back when they used it in the Sequoia as a base engine up until '12 or so.
I think vehicles were used by hot shot drivers for oil industry parts
I'm just being snippy as the owner of a little brother 2UZ-FE :).
A few of the very old 2UZ-FEs have also had head gasket problem. IMO the best way to avoid those is routine coolant flushes to keep the coolant form becoming acidic. I'm not seeing any coolant changes on the service record for that GX. It's also quite interesting that it had 255,003 miles in January of 2020, then 332,841 miles by July of 2021, and 418,893 miles as of October 2022. This individual was driving nearly 100K miles a year.
It shows up in the 15 page but looks like transmission was replaced at 262k miles... not seeing mention of coolant change either. Maybe coolant first change after water pump failure after 400k miles.
Coolant was probably super acidic at that point.
Still, I'd be happy of my GX470 makes it to nearly 500K miles. That would be about ~23 more years of me driving it, and the rig would be over 40 years old at that point. Seems a long shot that I'll still own it in 2048, but you never know :).
