Acrad
GOLD Star
Funny.. and KBB is usually low for my area
2025-08-29 (467,800 mi) — Toyota of Gallatin
Service: Multi-Point Inspection, General Concern
Description: Towed in for possible head gasket issue, inspected
2024-04-03 (463,183 mi) — Toyota of Gallatin
Service: Multi-Point Inspection, Oil/Filter, Tire Rotation, Air Filter
Description: Oil & filter change, rotated tires, replaced engine air filter
2024-03-01 (461,050 mi) — Toyota of Gallatin
Service: Brake Booster, Alternator, Battery, Wheel Bearing
Description: Replaced brake booster, alternator, battery, wheel bearing; heating concern noted
2023-09-29 (457,650 mi) — Toyota of Gallatin
Service: Drive Shaft Replacement, Inspection
Description: Installed drive shaft, performed inspection
2023-04-11 (456,014 mi) — Toyota of Gallatin
Service: Vibration Diagnosis
Description: Rear bearing & drive shaft vibration, warped rotors, recommended replacements
2023-02-28 (447,793 mi) — Toyota of Gallatin
Service: Water Pump, Drive Belt, Thermostat, Inspection
Description: Replaced water pump, drive belt, thermostat; multi-point inspection
2023-02-25 (447,693 mi) — Toyota of Gallatin
Service: Cooling/Temp Concern, Inspection
Description: Temp gauge moving, added coolant, dash lights on, inspected
2022-10-14 (418,893 mi) — Toyota of Gallatin
Service: Brake Inspection
Description: Brake grinding, replaced caliper, pins, pads, rotors due to fluid leak
2021-10-07 (347,496 mi) — Lexus of Nashville
Service: Transmission, Ignition Coil, Valve Cover
Description: Cylinder 3 misfire, oil in spark plug tube, replaced ignition coil, valve cover reseal, plugs replaced
2021-07-05 (332,841 mi) — Toyota of Gallatin
Service: Inspection, Vibration/Braking
Description: Replaced power steering rack, resurfaced rotors, replaced pads, studs/lug nut
2021-05-27 (325,012 mi) — Toyota of Gallatin
Service: Transmission Replacement
Description: Transmission slipping, replaced transmission & fluid
2020-02-19 (262,263 mi) — Toyota of New Bern
Service: Drivability Concern
Description: Replaced rear axle seal, shoes, brakes
2020-01-23 (255,003 mi) — Lexus of Nashville
Service: Burning Smell, Transfer Case Leak
Description: Replaced transfer case input seal, declined valve cover gaskets; loaner provided
2019-12-30 (253,677 mi) — Lexus of Nashville
Service: Transfer Case Fluid Leak
Description: Estimate for transfer case seals, burning smell from valve cover leaks
2018-05-03 (163,163 mi) — Lexus of Nashville
Service: Brake Concern
Description: Rear rotors warped, calipers deteriorating; oil/filter change; brake fluid service; replaced front caliper & hard line
2017-10-12 (147,682 mi) — Lexus of Nashville
Service: Oil & Filter, Airbag Recall
Description: Oil/filter change, replaced passenger airbag inflator, brake inspection
2017-04-13 (134,813 mi) — Toyota of Gallatin
Service: Presale Inspection
Description: Recommended cabin/engine air filter, wipers
2017-02-22 (121,450 mi) — Lexus of Nashville
Service: Oil & Filter, Inspection
Description: Replaced engine air filter, inspection noted wipers & cabin filter soon
2016-08-25 (105,615 mi) — Lexus of Nashville
Service: Oil & Filter, Brakes, Tires
Description: Rear brake replacement, new tires, alignment, front brake service
2015-11-19 (80,539 mi) — Lexus of Nashville
Description: Oil & filter change, reinstalled locking lug
2015-09-15 (75,651 mi) — Lexus of Nashville
Service: Brakes
Description: Machined all 4 rotors due to grinding & vibration
2015-07-16 (72,264 mi) — Lexus of Nashville
Service: Brake Pulsation
Description: Possible seizing caliper, warped rotors; repair deferred
2015-06-16 (70,535 mi) — Lexus of Nashville
Service: Check Engine Light
Description: Code P0010 camshaft actuator circuit; repaired damaged wire harness
2015-05-12 (68,181 mi) — Lexus of Nashville
Service: Check Engine, Steering Drift
Description: Replaced secondary air injection pump/valves; alignment recommended
2015-04-09 (65,001 mi) — Lexus of Nashville
Service: Oil & Filter, Air Filter
Description: Basic oil change, replaced engine air filter
2014-12-16 (57,001 mi) — Lexus of Nashville
Service: Oil & Filter, Battery
Description: Oil change, battery replaced
2014-09-04 (47,871 mi) — Lexus of Nashville
Service: Oil & Filter, Seat Recliner
Description: Oil change, seat recliner binding (declined repair)
2014-06-12 (42,764 mi) — Hendrick Lexus Charleston
Service: 40,000 Mile Service
Description: Oil/filter, tire rotation, air & A/C filters, belt inspection, detail service
2012-12-03 (28,562 mi) — Hendrick Lexus Charleston
Service: 30,000 Mile Service
Description: Replaced oil & filters, brake fluid, alignment, inspection
2012-07-04 (23,920 mi) — Hendrick Lexus Charleston
Service: 20,000 Mile Service
Description: Oil/filter, tire rotation, fluid check
2011-12-14 (18,635 mi) — Hendrick Lexus Charleston
Service: 15,000 Mile Service
Description: Rotation, alignment, wipers, air filters, driveshaft lube
2011-05-11 (13,580 mi) — Hendrick Lexus Charleston
Service: 10,000 Mile Service
Description: Routine 10k service completed
2010-10-26 (8037 mi) — Hendrick Lexus Charleston
Service: 5,000 Mile Service
Description: 5k service, buffed scratch, complimentary wash
2010-08-03 (4621 mi) — Unknown
Service: Smart Key Programming
Description: Programmed smart key
2010-08-01 (4079 mi) — Unknown
Service: Delivery Prep
Description: Clean for delivery
2010-05-11 (4078 mi) — Unknown
Service: Certified Pre-Owned PDI
Description: CPO PDI, detail, window tint removed
2010-05-10 (4048 mi) — Unknown
Service: ALB Campaign
Description: Computer updated per ALB campaign
2010-02-14 (6 mi) — Unknown
Service: Pre-Delivery Clean
2010-01-31 (5 mi) — Unknown
Service: Pre-Delivery Inspection
Description: PDI for USA all altitudes
Used Lexus GX 460 460 for Sale in Gallatin, TN | Toyota of Gallatin - https://www.toyotagallatin.com/viewdetails/used/jtjbm7fx1a5003663/2010-lexus-gx-460-sport-utility?type=cash
Service: Brakes
- Head gasket (suspected/inspection requested)
- Engine air filter (multiple times)
- Brake booster
- Alternator
- Battery (multiple times)
- Left/Right wheel bearings
- Drive shaft (replaced twice, one actuator order noted)
- Rear bearing
- Brake pads (front and rear, multiple replacements)
- Brake rotors (front and rear, resurfaced and replaced multiple times)
- Calipers, pins, shim kits (due to leaks or wear)
- Water pump (multiple times)
- Drive belt
- Thermostat
- Power steering rack
- Ignition coil (cylinder 3)
- Valve cover gasket kit (reseal performed)
- Spark plugs (full set replaced)
- Rear axle seal
- Brake shoes
- Transfer case input seal
- Front brake caliper & hard line
- Airbag inflator (passenger front, recall replacement)
- Wipers (recommended/replaced at least once)
- Secondary air injection pump & valve sets
- Wiring harness repair (camshaft actuator circuit)
- Tires (full set replacement, multiple rotations and alignments)
- Stud and lug nut (rear wheel)
- Cabin (A/C) filter (multiple times)
