Ok, so I replaced the rear shocks, removed and replaced the broken part of the brake line, and bled the brakes. It actually stops! Unfortunately when I went up the road, there is a grinding sound coming from the rear. I'm wondering if either of these are possible:
- I removed the rotors and calipers in an attempt to get the parking brake working. I loosened the parking brake a good bit and PB blasted a lot of it. The pieces move when I push on them from the inside of the wheel but the brake does not actually work. Maybe related to this?
- When I was doing this, I removed the rotors and the calipers. On one side, I did not know which bolts to loosen on the caliper and I accidentally released the brake pads. I put them backin as I thought they were and reassembled the caliper. Maybe I screwed something up here?
Trial and error over here. Thanks for all the help folks!
