- Year
- 1997
- Vehicle Model
- 80 Series
- Mileage
- 225000
- Color
- Black
Selling my '97 Triple Locked. I can send excel doc on all the work during my ownership. I have extra parts and goodies to go with it as a package deal. Used only OEM, equivalent, or proven upgraded aftermarket parts. I am glad to answer any questions you have. 225k miles. I have $26,500 in the truck. I am negotiable on price. Located in Greenville, South Carolina. I can send pics, videos, and facetime for serious buyers.
Tires, Wheels, Brakes:
315/75 R16 Mastercraft MXT (70% life) - 5 matching in rotation
4 Original 1997 Shouldered Lug and 4 Spare 1994 Tapered FZJ80 Wheels
New Tapered Lug Nuts
Extra Center Caps and original Shouldered Lug Nuts
New Brake Booster
New ABS Brake Pump
New Brake Master Cylinder
New Rear Passenger Brake Caliper
New Rear Brake Proportioning Valve
New Brake Pads
New Brake Bleeders
Slee Extended Braided Brake Lines
All Brakes Bled with new Brake Fluid
Parking Brake Adjusted
Suspensions, Drivetrain & Transmission:
ARB OME Coils and Shocks
ARB OME Steering Stabilizer
ARB OME Caster Correction Bushings
Delta Rear Bump Stop Spacers w/ OEM Bump Stops
Front Knuckles were done in 2020 w/ Japanese Sumo kit, slow seep driver
New Front Locker Actuator
Front and Rear Diff Fluid Done
Transfer Fluid Done
Drive Shafts Greased Properly
New Automatic Transmission Fluid (Dexron II/III)
Engine:
Newer AGM Battery, still under warranty
New Battery Terminals
New Fusible Link
New Alternator
New Spark Plugs
New Belts
Blue Fan Hub Done
Newer Radiator (2019?)
New Radiator Cap
New Thermostat and Gasket(s)
Toyota Red Coolant
Heater Hoses and Temp Switching Valve at Firewall Done
PHH Done
Coolant Bypass Seals Done
OEM Oil Filters Used
OEM Engine Air Filter
Full Head Gasket Job 2021 - Done the right way
Wiring Harness Wrapped and Protected
New Fuel Filter
Front Main Seal Done
Oil Pump Seal Done
Distributor Seal Done
Oil Cooler Cleaned and Gaskets Done
Valve Cover and Tube Gaskets Done
New Power Steering Fluid (AKA Dexron III)
New Charcoal Filter
Body and Other:
New Window Motor Rear Driver Side
New Door Lock Actuator Rear Driver Side
Custom Fab'ed Rear Hitch Mounted Spare Tire Carrier
Extra Hood for Future Restoration
ARB Front Bumper
Hella HID's
PIAA Fog Lights
Warn 9.5ti Winch w/ New controller
Under Hood Power Switch for Lights and Winch
Bowfin Roof Rack w/ Rear Loading Roller
New hood and rear lift gate struts
Pioneer Double Din CD, DVD, Bluetooth Radio Unit
Weather Tech Floor Mats
Cheap Seat Covers to protect the original leather
OEM Tow Hitch and Trailer Light Wiring
Curt Pintle Hook Hitch for 4 bolt rear cross member
New Power Antenna (need to install)
Other misc. parts to go with it
Used only non-ethanol from a new top tier gas station over last 3-1/2 years. Using High Performance Lubricants PCMO 10w-40 and Toyota OEM Filters.
New Brake Booster
New ABS Brake Pump
New Brake Pads
New Brake Bleeders
Transfer Fluid Done
Engine:
New Fusible Link
New Alternator
New Spark Plugs
New Belts
Blue Fan Hub Done
New Radiator Cap
Toyota Red Coolant
PHH Done
New Fuel Filter
Oil Pump Seal Done
New Charcoal Filter
Body and Other:
ARB Front Bumper
Hella HID's
PIAA Fog Lights
