How are the knuckles? Trying to figure out if they are worth buying or just another bling item.
I run the ARP studs. I did break 3 of them once. After speaking with Brian at FROR I believe the main reason I broke them was because I did not put enough locktite on them when I installed them. I had been wheeling in Moab and Colorado for 7 days and had not checked them like I should have. Returned home and wheeled locally and thats when they snapped. I have since replaced them with new ARP studs. I check my studs on a regular basis and haven't had any issues with them. I also run a hydro assist setup without a ram stop.Why the T-G knuckles? Run ARPs with the stock setup cheaper and just as strong.
Stop working on your pig and get back to work on this! Are you planning to go to GSMTR again this year and will you be ready to ride in the 40 or wil the pig be done?
Go with the Land Cruiser center with D60 outers. Then you can sell the 30 spline Longs to me for cheap.
Really doing the D60 outers sounds like a lot of work but it should be easier the second time you do it.
I decided to bypass thetoday & give some luvin to my 40 ;p I picked up this REAR 40 housing from Mister Larry Downey last night & just had to get awn it. Got the ends cut off, relocated the diff drain to the bottom, patched that hole, & located a housing vent @ the top. Next, I'll relocate new slots where the ring gear passes thru the housing, on the opposite side, & patch the old slots. Then, I'll grind the ends a little to press on the Ebay D60 inner C's. After that, I'll reinforce the top & bottom housing w/ 2 X 4 X 3/16" wall square tube cut in half. I'm building this hybrid almost exactly as the one I fabbed for my
Right now I'm not sure if I wanna go 35 spline cuz that means $$$. I'll reuse my RD02 ARB w/ 4:88's. The diff cover will be reinforced, similar to the Dynatrac style cover. I'll go w/ 4340 shafts so I don't lose any strength compared to the 30 spline Longs I'll be selling later.
Chuck,
This is a minor point in such a project, but how did you clean up the housing to raw metal so quick?
