LC_Hamma
The Anti-Leafer
After 3 TLCA events, I determined a few changes HAD to be made:
1 - shorten rear lower links & raise upward to the frame cuz they hang WAY too low.
2 - revise skid plate to be 2 piece for easier access to tcase & front driveline.
3 - design heavy duty frame panhard mount since I broke it clean off on the way to Hal Johns trail.
4 - new hydroboost brake unit from Vanco, bored for hydro steering.
5 - new hydro steering kit from PSC.
6 - TG's Six Shooter knuckles.
I started on the frame links first. I cut off the old mounts from the rear of the skid plate & still used the fronts mounted to the front skid crossbar. First pic is the old setup when I first built it. I furred out the frame mounts some & ground to the correct slope to line up with the rear axle lower links. Next, I'll show how I braced it to the frame.........
Allotta fitting went into this but I finished it up! I won't be gaining any skid plate height at the tcase, but I will be clearing up the frame area for better clearance:
I was running the stock stuff & sheared all 4 w/ 36's. I have since retapped them for 12MM fine thread grade 10.9 & haven't had any problems yet. There's hardly any mat'l. left between the stud holes & the kingpin hole
Sorry dude you hurt my feelings so no can do
No one will find my special wheelin place Muhahahaha!!!!!
