I am sure you are as sick of hearing about this topic as I am researching it. Per normal I am doing a manual swap into my BJ74... which would be cool and all if I didn't have a 1989 which means I have an 8 bolt. Literally the hardest damn flywheel to come across (and i live in japan at that)
the parts vehicle i am getting is most likely a 6 bolt. we haven't been able to open it up yet and then year/month of the cruiser is basically right on the line between 6 and 8 bolt. (but I don't have that kind of luck anyway)
So in my research I have found a part number for the 13bt 8 bolt flywheel 13405-58012 (we all know it isn't there)
then I found a website saying the 3bii and the 13bt are the same (maybe they just both work) with a part number of 13405-58020 but as luck would have it... that website is the only one that has said flywheel available.
Then I started more and more and more research (pretty much researching is more work than do the trans swap)
Long story short I came across a toyota Dyna that came with a 3b.... in 1993..... and has an 8 bolt flywheel so whats the chances of that one fitting (and you guessed it.... its a different part number)
anyway long story short, has anyone ever used a flywheel from a 3bii in a 13bt (i don't mind if it is slightly smaller like the 6 bolt guys are running into)
has anyone used an 8 bolt flywheel from a dyna (3b engine)
or for that matter does anyone has some knowledge that I have found yet on some magical flywheel that exist that will bolt up?
Thanks in advance
Thanks in advance
