Oh, I definitely rue the day I ripped out all the emissions stuff every time I fill it up, but it's all gone now, and I need to deal with it.
That's the point of my question: In my mind, given that this is NOT a "green" vehicle at all, if I go to the trouble of dropping the tank to replace all hoses, why can't I just duplicate the design of my '66 Ford and be done with all the plumbing and expansion tanks for good?
Here's the current condition:
Big tanks under the floor: Gone
Charcoal canister: Gone
Emissions "computer", speed marker, etc,: Gone
Remaining lines underneath the floor that used to run into the big tanks, or continue up to the firewall: I've T-ed them underneath the floor to (1) factory hard line that runs up to the firewall, and rubber-hosed this to a factory hose nipple on the underside of the air cleaner. I assumed the vapors would get sucked thru this line into the intake when the truck is running.
The fumes are bad when I fill it, and eminate from the driver's side cargo panel area, although I can detect no liquid leaking. The cargo panels are not installed.
The fumes go away after 30-40 miles.
So yes, there must be a small leak in the expansion tank area or somewhere underneath when the tank is full. So when the tank is down, I'm trying to reason out why the Toyota design requires all this plumbing IN THE ABSENCE OF ALL THE EMISSIONS STUFF I'VE REMOVED, as opposed to a simple vented design like my '66 Ford.
I realize this has been beaten to death before. Just looking for a different spin than the "restore it to stock" approach.
