- Thread starter
- #21
Rear hub overhaul. I replaced both bearings, raceways, and repacked. I then installed, and realized I installed the inner seal in backwards
. So had to go back in, and replace with a second inner seal, as it is a one time use item. Then I went to install the pin screws... snap. One sheered off into the hub. Had to drill it out, and wait for new parts. Parts arrived, and went to tighten hub bolts...snap. One sheared of, thankfully with a nub sticking out, but with no threads. Then I had an idea, why not use the drill, and some map gas, and just reverse it out. Worked like a charm. Did all 6 studs in under 5 min. 23 year old hardware has a tendency to break, I highly recommend replacing as much hardware you can, as you come across it.
