ToyotaTechnical
- Thread starter
- #41
Over the past months, I have been doubling back on all the systems. When a vehicle goes from sitting 20 years, to cruising the Dallas Tollway at 80MPH... junk will be kicked up.
The big focus has been fuel delivery. Fuel filter, injectors, seals, grommets, FPR, Damper, etc.
I pulled the injectors and had them sent out to be cleaned by InjectorRX. Injector 3 was the worst at 17% plugged. Once the fresh injectors went in, I also adjusted TPS and Idle control sensors to FSM spec. This thing purrs now. Here are the results:
New Injectors and FPR:
Fresh OEM fuel filter went in. Here is old dirty filter:
Old and dirty injectors prior to cleaning by injectorRX in Houston:
Old injector spacers, Old V new:
Parts used:
Replace injectors after cleaning.
6x 90561-10004 : injector spacer
6x 90301-19006: injector o-ring
4x 90430-08011: brass union gasket
90430-12005: lower gasket
6x 90480-13005: Grommet
3x 90561-08023: Spacer
Fuel pressure regulator NLA, but OEM alternative: 23280-74100
23207-46010 / 23207-20011: Pulsation Damper
23232‑28010: Upper Gasket
90430‑12005: Lower Gasket
6x Injector grommets: 23291-73010
4x 90430-08011: union gasket
Cold Start injector gasket: 23293-74010
Fuel Filter: 23300-69025
Parts used:
