FZJ80 Sun visor
Third bush on the right
Is this what goes wrong after sun visors age and bust? Is this part replaceable and if so where? Super glue doesn't hold the pressure of flipping up and down. Help....this is on the Princess' side!
Go to Auto Zone and Get a 2 part epoxy that will hold. In addition you can order this from the dealer.
Loctite two part epoxy for plastic (Lowe's) might hold, roughen the surface first and build up a layer across the back side of the part.
Thanks, I will give the epoxy a try and see if it holds up.
HI Guys,
I went to the Rosin see thru visors. Couldnt be happer that I did this. Expensive, but cheaper than the factory visors.
If you decide to go this way and call them, remind them of the group buy that was done earlier. They matched it, if I remember correctly, about half off.
