I have this problem with my airbag light and can not figure it out no matter how I try.
It would be so easy with a informative lil video wink wink
+1 on the video tutorial
As much as i love a good video it really is as easy as following the instructions...
it took me 10-15 tries at least to make it work. Making some longer wires helps. I used two 3-4ft wires and a good ground bolt. You should hold them just longer than you think to get it to register.
Airbag reset:
Go to DTC in engine bay. Small black box on pass side near firewall.
Put one wire in Tc
Put one wire in AB
Put ignition to on.
Touch
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 5 sec
That should do it. Hope that's clear. You need to do them kinda fast. If it don't work keep trying. I had to try several times to get it right. But it works.
I’m convinced this process doesn’t work as advertised without the tool. I’m growing old counting the seconds and traveling to and from the ignition and the engine bay!
it works. I did it on mine with two pieces of wire. Took me about an hour of doing over and over but eventually got it.I’m convinced this process doesn’t work as advertised without the tool. I’m growing old counting the seconds and traveling to and from the ignition and the engine bay!
It works. I reset my light numerous times successfully, but the light would come back on again and again. I bought a replacement airbag sensor assembly and the light has been off ever since. I had a code 31 airbag light.I’m convinced this process doesn’t work as advertised without the tool. I’m growing old counting the seconds and traveling to and from the ignition and the engine bay!
