Worked i did went fast
Just tried this technique and worked on the first try! I used the ground for the factory horn.It worked! I just went really fast. I didn't count one second, I just went back and forth. Thanks group
Perhaps I’ll give it another shot.took me 3 attempts. The key is switching wire to wire FAST. 0.2 Seconds is pretty quick.
Hey quick question, does this work even if the airbag light is blinking? Or is this only a solution if the airbag light is solid and doesn’t blink?Airbag reset:
Go to DTC in engine bay. Small black box on pass side near firewall.
Put one wire in Tc
Put one wire in AB
Put ignition to on.
Touch
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 5 sec
That should do it. Hope that's clear. You need to do them kinda fast. If it don't work keep trying. I had to try several times to get it right. But it works.
In my experience (97' FZJ80), it does not clear a steady blinking airbag light. I have tried the sequence multiple times to where I have gotten it to blink rapidly at the end, but it will not actually clear it.Hey quick question, does this work even if the airbag light is blinking? Or is this only a solution if the airbag light is solid and doesn’t blink?
