Good info.. .417k is incredible... not just the fpump, but the vehicle in general... Put to good use~
Interestingly, we had a loss of power on hwy speeds recently (and hills)... had a CEL flash but go away.
The code was P0420 for cat inefficiency, which I usually just erase the codes for the last few years. Still passes CA smog fine.
Also, the VSA TRAC/ VSA OFF was on too, and i heard it can pull back the car's power (like a safe mode?).
This was because of Zero calibration for Yaw sensor was off, for some reason. Did the OBD2 jumper procedure, and all the lights are off, not, and power seems to be back to normal. ('04 LX470 267k miles).
I did also pick up a Denso fuel pump from RockAuto just in case. Gonna hold onto it as a spare, just in case.
