I might, instead. Make a snake out of braided wire or a coat hanger and probe up the fuel outlet...if no, then prime the line, put a clear line on the other Blow air in that line backwards with compressor, it should unclog.
I'm having similar issues with my '78. It ran fine when parked last year but won't start now, not getting fuel to the carb. I have fuel to the pump as when I pulled the line at my filter, gas poured out. I have a trollhole carb so no return. If I have fuel to the pump, the pump should be good, correct? I'll have to pull the line at the carb to see if its a carb issue or a line issue, but I only run non ethanol premium, so it that shouldn't be an issue. It runs fine off of starting fluid.
