Had my independent mechanic here in the beach cities replace front AHC shocks, front pads and rotors, all OEM.
In the process he stripped out one of the holes in the left front hub, and had to remove it, heli-coil it, and added that extra work/part to my bill : (.
I'm assuming it was one of the holes where the brake rotor is attached to the hub with bolts. Is this a common fail item?
Since then, I've noticed a sound, sort of a whining, that seems to come from that left front end. Sound seems to have a "warble" that increases/decreases with speed, mostly noticeable over 35 mph, and is more apparent under acceleration/load than when coasting.
I'm trying not to be pissed about the stripped hub hole because in my mind its likely their fault for misusing air tools, but I'm OCD and that kind of crap annoys the hell out of me. To be fair, they did offer me the option of heli-coil or new hub, but as it was late in their work day (a Saturday) and they're closed the next two days and I needed the LX back for a road trip, I chose helicoil, based on their guidance that it shouldn't affect anything.
I'm going to bring it back there to have them access, but would like to have somewhat of an idea what the issue might be before then. My guess is bearings-related? Or is it possible that the helicoil would cause the hub to be out of balance enough to cause this?
'06 LX 470 with 137k miles. I'd driven it probably 750 mostly freeway miles since then and the sound hasn't changed.
TIY and yes, I was dumb to go for the $140 helicoil quick fix. In hindsight I should've used that opportunity to replace hubs and bearings/seals as they're all original.
Are there any 3rd parties selling complete OEM hub/bearing assemblies already put together that can be used, like what Blue Pit Bearings does with the 4Runners/GXs?
Drove 50 miles on the freeway and exactly same symptoms....happens under acceleration load, etc. noticeable at 35+mph.
